1 - 2 of 2 Posts
Ok I'm building my first forced air engine so this may be a stupid question idk...so I'm wondering if theirs an engine management system that will allow me to change the ECM tune for different boost psi by switch instead of retuning the ECM like if I wanted have a switch for 5 10 15 20 psi lower setting for the street and higher for the track I'm still in the early stages of my 95 gsr build so obd1... Im currently doing the roll cage and body work it's completely stripped to bare she'll just about I'm doing a wire tuck I'm using wireworx they will wire in plugs for whatever I need so any advice on my question would be appreciated thanks in advance
You won't have a separate tune or map for different PSI settings. You'll have one tune.
You can have a switch for "low" & "high" boost if you'd like, but it's still one tune/map. All the switch is doing is cutting boost, that's it.
1 - 2 of 2 Posts
