Hey guys I tried searching "motor silk" but nothing came up. Anyway, has anyone ever heard of "motor silk" and is it compatible with all types of engines? I remember adding this to my car...I dont know if that was a good idea or not...its supposed to make your engine run smoother and it chemically bonds making a very silky smooth surface on the metal parts or whatever inside the engine.
My car is a 2001 LS...no engine mods except AEM CAI. It has about 72,000 miles now and its burning oil....about a quart every 500 miles....I do not know what the cause is...visually I see no leaks and my engine sounds and runs fine...no loss of power. I'm using 10W30 regular motor oil...i havent tried synthetic yet.....what should i do please help
**UPDATE** here is some info on "motor silk"
MotorSilk™ Engine Oil Treatment is designed to extend the life and operating range of your engine. It blends with your existing engine oil and contains boron-based components that protect vital working parts from friction and corrosive elements.
The main component of this blend is Boron CLS Bond™. Boron CLS Bond™ is a U.S. Patented ingredient whose basis was developed in U.S. Government laboratories. "MotorSilk™ Engine Oil Treatment" with Boron CLS Bond™ is many times slipperier than PTFE (Teflon) that is often found in engine oil additives.
However. Motor Silk™, (aka Motorsilk™) with Boron CLS Bond™ is not an oil additive; rather, this advanced technology - developed at the Department of Energy at Argonne National Laboratories - creates a permanent Crystal Lattice Structure on all metal surfaces - 85% the hardness of a diamond - virtually eliminating friction and wear in fluid systems.
The new surface also blocks oxygen to prevent corrosive activity. This micro-layer of protection is bonded to metal surfaces with strong covalent and ionic bonds (atomic and sub-atomic bonds). It provides a long-lasting, low-friction surface impervious to most contaminants. Most treatments last as long as the vehicle.
Click here for motor silk info
