1 - 2 of 2 Posts
I've heard of them but don't think they should be considered unless your stock mounts need replacing as a whole or if you are putting an H22 motor into your car and will need new mounts for it.
If you just want to reduce engine flex then you don't need to spend the $350 for them because getting a set of $30-$40 inserts will do the same thing. It's your call if you want to spend the money, I'm just saying there are less expensive alternatives.
1 - 2 of 2 Posts
