1 - 11 of 11 Posts
is there any advantage for getting a mono amp to power a sub over bridging a 2 channel amp?
mono amps seem to be a bit pricier and produce less power. any explainations?
one channel can power up to two subs. With a two channel amp your wasting a whole channel.
What amps where you looking at??
Discussion Starter #4
I was looking at the Rockford Fosgate 200M. i puts out 100watts RMS 4ohms. and 200watts RMS 2ohms.
i need an amp to power a Kicker Comp Vr 400watts RMS
yea man that rockford amp wont even touch that sub i bet.. i have a pioneer premier 2 channel that puts out around 300 watts, and 2 10" JLs... it doesnt bump really all that loud. im lookin into getting either a rockford or a kicker 800 watt amp right now
If you only have one speaker why would you want a 2 channel amp. mono block amps where made for subs. How many ohms does the speaker run?
fosgate punch 200 monoblock? it would touch that sub..it'll push it pretty good too...either or would be fine...but the monoblocks made to take a beating...if its a dual 2...then just parallel it and bridge mono on a 2 ch amp...it should run fine...
I like the idea of bridging an 2 channel amp. If you get a quality high output amp and bridge it you'll have plenty of watts pushing you sub. Then if you decide to get something different you still have a 2 channel amp that you will be able to use. I think they are more versitle.
1 - 11 of 11 Posts
