Are there fuses that I'm missing?
I disconnected my (-) battery cable, worked on my
keyless entry system a bit, and then reconnected the
(-) cable. When I put it back on, a got a spark a little
larger than normal. (Before I reconnected it, I undid
what I just wired with the system because it wasn't
correct....so it's not like I have something hooked up wrong).
Now my keyless entry part doesn't work. The module
clicks, and the relays click (for the actuators), but
the locks don't want to move. I checked ALL fuses,
under the dash and under the hood. I just looked at
them though, not DMM tested. I checked the module's
fuses, and everything that should be getting power is
getting power (and same for ground).
What am I missing?
What am I missing?
