I have this weird problem but i'm not sure what it is.
Recently, it has been bogging a lot. Sometimes when I get out of first gear, it bogs for a bit then goes on fine, then when i shift into 2nd, it bogs for a bit as well.
Is it the distributor? Do i need a new one?
Thanks
has the check engine light come on yet? generally, the check engine light comes on from mis-fires. any leaks from the heads? how many miles are on your 91?
the check engine light won't come on for the 91 because of that. When mine did that it was because I had bought some spark plug wires from autozone "double silicon" with sucked, and I had to exchange them every month (warrenty) until I bought some ractive wires(the bomb). check those then cap, rotor and plugs.
