I recently got a 95 Integra and realized the dude I got it from cut the springs, so I ordered some Megan Racing coilover sleeves to replace them. I am not going to track my car, I just need raise my car because it is way too low. I am just using it as my DD, nothing else. I am in a bit of a budget so should I return them and get some other ones. Any recommendation for other affordable sleeves? Here are the specs
- AISI 6061 CNC Aluminum
- Spring rate 450 lb/ft Front and 350 lb/ft Rear
- Spring color- RED
- Coil-over sleeve inner diameter: 2 1/16" or 52.38mm
Get oem springs, or type r suspension.
If its DD then almost anything else is out of your price range or they won't be a good ride for DD
