1 - 2 of 2 Posts
I have a stock b18b one bottom end I have a GSR p72 head freshly redone supertech dual valve springs 95 lb blox titanium retainers , blox lmas , Ferrah flat valve OEM valet seals , plm header , blox intake , blox tb an whale air intake would it be worth gettin 98 spec itr cams for 400 vs my gsr cams or skunk2 stage 1 tuner cams?
01 vogue silver metallic gsr
The gsr cams lobe profile isn’t drastically different then the gsr but I’d bet it’d complement the mods you have nicely. my vote would be stage 1 or 2 of something else and getting it tuned on something because once you change the lobe profiles you’re affecting a lot of other functions of the engine. Type r would probably be best if your running your stock ecu but personally I don’t think youll see very much if any increase in hp. Keep your timing dialed in and valve lash adjusted, build sounds really nice, good luck
1 - 2 of 2 Posts
