Hey guys so I’ve been trying to get this for a while now. I pulled the trans apart to fix it wasn’t shifting into 3rd gear took it apart everything looks fine but the snap ring for the 3rd gear synchro (just had a new carbon synchro installed about 100 miles) so I replace the snap ring and input shaft bearing put everything back together made sure the tab is at 12 o’clock position case goes all the way on with no problem don’t even have to wiggle the shifter but the second I put the bolts in and tighten it up the input shaft stops spinning. Any help ????
Did you flip the trans over to seat the top bearing into the big circlip on the case? Did you spread that circlip apart to allow the top bearing to seat into it? Are you following all the steps in the Helm manual?
