1 - 18 of 18 Posts
ok sometime when i am in drive at a stop light or waiting in traffic a loud vibration will start happening under the car. when i put it in neutral it stops. this is very aggrivating and is very noticable. if you are next to me in traffic or at a light and have your window down, you could hear it.
when i put it in neutral, it stops, could this be my exhaust pipe is not mounted down correctly??
also when installing my header to the cat under the car when i was pulling the cat closer to the downpipe to bolt them together i heard a pop, could this be one of the exhaust hangers or something?
nothing is leaking that i can see at wot
my buddy just had the motor swaped in his civic and now the exhaust at idle vibrates against something. its about right under the shifter position that its doing that....maybe u have something similar.
hmm so the shield that has the notches at the bottom is the culprit?
if i take it to an exahust guy can he tell that?
i am about to take the cat off and instead of doing test pipe i am going to do 2.25 all the way back to my 2.5 inlet for evo2 muffler
just bought my '95 gsr recently, ever since i've had it there has been a loud metal grinding/buzzing noise up front at about 3100-3400 rpm. I know there are previous cases of this, but all of those forums are way old. Seems like you guys have had similar noises on this thread. Wondering if anyone lately has had this problem and how to maybe fix it...? Thanks!
Just took a look/listen. It sounds like it's coming from the stock headers, or somewhere in that area. But i checked the heat shields and bolts and they all seemed okay... thanks for the help btw!
had the same noise just last week. i took it to the boyfriend, and he found it to be the heat sheild. he put some hose clamps around it. i haven't heard the noise since.
Sounds like my headers... This is prob a good excuse to buy new ones
Maybe it's just that heat shield... Is there anything wrong with taking that off...?
1 - 18 of 18 Posts
