PLEASE READ AGAIN
MichaelDelaney on Feb/29/04 said:
uhh no.
af ratios are guides like a compass and should not be your final goal. torque is your final goal in tuning. af ratios in combination with engine temps should be guides as to whether you push the tuning further or back off. you don't tune to a specific af ratio number ever. they are just reference guides.
you want to look at your torque curve at those rpms.
if they are dropping and the engine temps are way off the roof add fuel and see what it does to the torque curve....
I can tell you that for most people with i/h/e (no cat upgrade), they don't run too lean. In fact the stock ECU runs way too rich in partial throttle and in WOT. There's not enough advance and the injectors overfuel for the added flow you get from an i/h/e.
I'd check your MAP sensor to make sure it's functioning correctly and make sure your fuel injectors or fuel filter aren't bunged up.
running this lean is not usual for an i/h/e setup.
this is coming from 9 years of experience fooling around with these motors and I left i/h/c/e 5 years ago...
some people say shoot for 13.0-13.5:1 for N/A at each setting point but it varies from engine to engine. You really have to look at the torque change (if it budges in the direction you want) with the fuel adjustments. Some people need 13.8 or 14.0:1 af ratio. If the engine temp spikes, then I back off on the lean down. But I don't stop leaning down just because it's 13.5:1 af ratio. You have to look at thw whole picture in each situation: what the af ratio, torque, and engine temps tell you together.
The v/t unmt is the correction for the fuel in the rpms between the old VTEC switchover point to the new one.
eg. if the old VTEC was 4400 rpm, the nonVTEC fuel map goes to 4400 rpm and then the VTEC fuel map kicks in at WOT. If you move the VTEC to 5200 rpm, the old setup will have you running a VTEC fuel map from 4400 to 5200 rpm when you should have the nonVTEC fuel map there instead. You'll be running too rich in those rpms.
you should usually lean down with v/t unmt.
