1 - 11 of 11 Posts
my clutch when pressed down has no resistance so i looked underneath and all of the brake fluid from the clutch master cylinder has leaked out does anyone know how to replace the master cylinder or no if it may be a broken seal that i can replace instead?
yes its very easy to replace.
Take the lines off the MC, then on the inside of the car by the pedals, there its a rod that has a cottor pin take that out. remove the two screws and it comes out......
SRH_Integra on Jan/29/06 said:
If you're gonna get a new CMC and you're into "spirited" driving, then you might want to check this out.
Omni-Power Quicklutch Master Cylinder
The failure rates on those when they were originally introduced was almost 100%. I know they were working on revising them because of it. You might call and inquire before shelling out extra for one.
1 - 11 of 11 Posts
