Holy Cow. Yeah, 2 inches is like way too high.
I'd take em' off, or just let them settle in first, and wait to see if they'll sag down a little.
Also make sure you installed them correctly.
so bump stops may be the problem, u think that would solve that problem or do u think the springs are defective in the rear i just think they are to high
Your car may be sitting on the bumpstops in the rear, thus causing it to be so high.
Alot of aftermarket suspension manufacturers will tell you to cut the bumpstops down some due to the drop.
Make sure to take a look.
If you took your car to be installed be a regular local shop, they didn't cut your bumpstops. I worked at a shop before, and we couldn't do no customizing.
Basically only Stock spec, or installing.
I believe to customize at a shop requires a different shop liciense.
I've seen Tokico struts come with new bumpstops, unlike these ****ty KYBs.
yeah i have aftermarket bump stops that are like an inch long they were on my coilovers
Related Threads
Team Integra Forums
2.7M posts
141.5K members
Since 2002
The Team Integra community is a forum dedicated to Acura Integra enthusiasts to discuss engine building, suspension, repair, detailing and anything else Integra related.
