Rod knock? Are you low on oil? Um, did you over-rev it? Does it idle horribly and shakey? It could be a number of things... Try to figure out where the noise is coming from. And is it more of a ticking sound or a knocking sound? Do you have any check engine lights? You could have rod knock or have the valves out of spec and ticking or maybe even your injectors are ticking...
