1 - 2 of 2 Posts
How hard is the down pipe to remove on a base model? I have a really bad leak and haven’t gotten to look under it but I’m taking a guess it’s after the manifold. Also where’s a good place to get a replacement if that’s what it is? I don’t mind getting a straight pipe instead of a cat. Converter
thanks
It's not very difficult. If it's leaking bad, you'll see black soot where it's leaking from. But I wouldn't suggest removing the cat unless you have KPRO. If you remove the cat it will be stuck in limp mode & you won't be able to rev past 4K.
1 - 2 of 2 Posts
