Removing the pry rods is an additional layer that I plan on using. However, I have seen several instances where thieves used a screwdriver etc to pry off the door handle and manually unlock the door via the push rod. The jimma appears it will brace the door making this more difficult. An additional feature would be the resistance to slim jim techniques.letsdrive on Sep/08/07 said:just get some four door handles then you can take the lock rods out all together. if youy already have keyless entry it is the way to go....
