1 - 13 of 13 Posts
I was thinking of getting the JDM Type-R Sedan exhaust with b-pipe for my 95 GS-R Sedan. Does anyone know if it's a direct bolt on or will I have to get make an extension or change the points where the hangers are? Also, does anyone know how loud the exhaust is? Thanks.
Well, since not many of the Type R sedans were made in '97, and I don't think there were any USDM versions (although I could be wrong, you might have a tricky time finding one. I would imagine the muffler is the only part you really need and I don't see why Honda would use a different one on the sedan than they do on the coupe. I mean, the GSR sedan muffler doesn't look any different from the GSR coupe one, does it? If you can find a Type R muffler only then you can probably just do the change. If you are looking for a real increase in performance then its going to be more than just muffler swaps you'll want to do. There are actually several other mufflers I'd get if I was looking for performance. If you are just trying to swap out as many Type R parts as you can, then I understand the desire for the exhaust. I still think the muffler is the only part you need. The rest of the pipes are likely the same as what you have now.
I can get a type r sedan exhaust from the cat back for cheaper than almost any aftermarket exhaust. The exhaust is 2.365" throughout. I just don't want to switch out the exhaust just for the sake of "Type-R." I want it for the b-pipe, exhaust, performance and the quieter sound. I was just wondering if anyone knew if it was a direct bolt on to a 95 GS-R sedan?
Jngrbrdman on Feb/03/04 said:
...I don't see why Honda would use a different one on the sedan than they do on the coupe. I mean, the GSR sedan muffler doesn't look any different from the GSR coupe one, does it?
The JDM ITR sedan muffler has a longer tip on the end that the JDM ITR coupe. Other than that, they're the same.
I'm pretty sure the hangers are the same, but the b-pipe might be a little short. Kill two birds with one stone and get the pipe extended at the cat while eliminating the bottleneck flange.
BTW, the JDM ITR sounds nice. A little growl (even more so in the mid to high RPM's), but otherwise a stock sound.
1 - 13 of 13 Posts
