Is the jdm gsr engine worth getting for an engine swap?Endless performance in Houston, Tx sells and installs the jdm gsr engines that are suppose to have 180hp is this correct?and is it actually worth getting?
I agree with Mike. The SiR-G's viscous slip differential is better than nothing, but take into account that you can get a helical gear differential out of a Type-R on eBay for a couple hundred bucks. If the difference in price for the JDM and USDM engines is more than that, obviously it may not be worth it.Michael Delaney on Sep/04/02 said:10.6:1 CR isn't going to stop the guy from running 8 psi boost. If you get an engine with the LSD option in the tranny then it may be a good deal.
