Well, I just finished getting the jdm b18c motor in my GS-R. Now, when I try to start it, it acted like it wanted to start, but then just shook the car violently and sputtered like it was firing out of order or something and died after it turned over once or so. After that it threw code 10, "Intake Air Temp." I checked, and sure enough I had the wrong clip plugged into the IAT sensor. The right clip was just dangling behind the intake manifold. Now the clip that WAS in there is just dangling. Its bundled with a clip that clips into the throttle body, I don't think it's the throttle position sensor, thats located on the side of the TB toward the rear of the car, right? This is toward the front. So I don't know where the clip that is a duplicate of that clip goes.
Anyway, having fixed that problem, now there is no CEL. Hooray! Unfortunately all that means is i have no way to diagnose my problem
. Now when I start the car I get a loud POP. Kinda like a backfire, but not from the exhaust.
And thats pretty much the end of the story. I don't know if the car dies after that. I'm just assuming it does, but as soon as I hear that I'm ready with the key to shut the ignition off. I wasn't expecting the motor to just fire up, so I was ready with quick hands to shut 'er down.
I pulled the plugs, and they are covered in gasoline. I smell a real heavy smell of gasoline. But when I ground the plugs on the valve cover and turn the car over, they all spark consistently.... Last I checked, gas + spark = fire. But that equation might not hold true if I were running on more than a combined 6 hours of sleep for the past two nights.
This motor is from hmotorsonline. I can't think of anything else atm, I'm terribly tired and need to go to bed.
If anybody has any ideas it would please me very much........
P.S. I WANT A CAR!
P.S. I WANT A CAR!
