· Registered
i installed USDM 22mm ITR rear swaybar.....and it's simply "WOW" i love it. so much better for conering. i can't wait to test drive my teg on downhill mountain road.
best upgrade i've ever done so far.
· Registered
it is an excellent upgrade, and install time is about 30 minutes. It'll (large swaybars) make a bigger difference in your car's handling than any single part out there.
· Registered
I put in a jdm 23mm sway and asr subframe brace a couple weeks ago, Im loving it! However I never knew the limits of the car before that :( But I took it to a parking lot to give it a whirl, my car was planted! Tried to swerve enough to lose traction and couldnt. It was a small parking lot but awesome none the less. Took awhile to install because of seized bolts and the darn LCA's not cooperating.
· Registered
i did it myself, it's really easy if you have the lifter. it took about 30min i think. if you know a mechanic, they can do it for you and just pay $20 for installation. the article explains well. everybody can do it. if you can get 23mm, get one because 1mm makes a big difference.
