has anyone since zigga found out how to take out the center console peice or the drivers side large vent. the large vent has the sunroof button on it and center concole with the heater and stuff.
I took mines out...but that was because I had the whole dash out. If i'm not mistaken, there are screws from the back that hold it in.
The drivers side piece, you must take out the whole housing of the sunroof switch, you can see where the housings rests into the vent, take that out, and there is the screw to get it out.......then the center one, you need to pull out the hazard and cautoin buttons and take out both those screws, then get under the dash, passenger side, and you can see a cable attached to a swiveled thingy, disconnect the cable, now you can take it out!!! Good luck!
