1 - 2 of 2 Posts
1994 Acura Integra LS
Hi, just got my car. It seems that sometimes when I pull of the highway the car will not go into any gear. The only way i've been able to get it to go into gear is by turning it off. Then it will. This is still a problem though as I obviously don't want to be in the middle of a commute and have to pull over. What could be the problem with it? Thanks for the help I appreciate it.
Brendan,
Check out my post here and see if this also applies to your situation...You might need to check or flush your transmission fluid if automatic. If you have a manual, that's a little different. It's in chapter [lucky number] 13 in the factory service manual. Hopefully you downloaded one.
Auto transmission issue
1 - 2 of 2 Posts
