1 - 1 of 1 Posts
Hello, I have a 1998 Acura Integra RS. A few months back I did a tan to black dashboard swap. When I did the dash swap, I swapped the harness from my tan dash (worked perfect) to the black dash (was spliced up). After installing the black dash, Ive came across the issue of not having cluster lights (cluster works fine, tested in another car). Ive noticed that the clock on the center of dash also doesnt Dim anymore when turning on the headlights. Everything in the cluster works besides the background lighting. The harness is grounded behind the radio and checks to be good. Yes all fuses are good as well. Checked the inside fusebox along with engine bay fuse box.
Issue #2: I have lost blinkers/Hazards. Using the turn signals doesnt work at all. No clicking, no lights, etc. Was told it could be the emergency hazard button because its a relay? Just wanted a second opinion or maybe someone who could back up this potential fix.
Thanks.
1 - 1 of 1 Posts
