I have an apparently bent valve in my 1996 Integra LS. A couple of months back I posted that I had a stuck exhaust valve on this car. I knew that it was in fact an intake valve, but when I sat down at the keyboard, it came out "exhaust". I reported that the rocker arm was laying loose on top of the head, I had assumed that it must have been assembled that way, since I could find no damage to the cam or rocker arm. I had bound the rocker arm on top of the head as I was replacing the valve cover after changing the timing belt.
I had noticed that the engine was running on three when I had moved it in to change the belt, but I figured that I'd worry about the miss after I replaced the belt. After I found the stuck valve, I removed the head, removed the valve, cleaned the gunk from the stem and reassembled everything. But, the engine still had a miss. When I did a compression check, cylinder one had zero PSI, while the other three had 145-150 PSI. So, I pulled the head again.
This time I found that I had a bent intake valve on cylinder one. Had I looked at everything when I had the head off for the stuck valve, I would have probably found the bent valve! I replaced that valve and reassembled everything again. The car ran well for about 75 miles and was running well when I parked it. Next time I tried to start it, it was running crappy again! I couldn't face going into it again so soon, so I let it stand for about a month. Last night I got back to it. Found that I had good spark to all four. Then pulled the plug wires, one at a time, and found that it was again number one which was missing.
Compression test again showed zero PSI on number one. When I removed the valve cover I found a rocker arm laying loose at the number one intake valve. This is the same valve which had been bent the time before! Using a big screwdriver, I could pry that valve down, but it would not come back up. I assumed that the timing belt must have jumped a notch or so, so I turned the crank so the timing mark lined up with the mark on the cover, and then checked the alignment marks on the camshaft sprockets. They were PERFECT!
My question is, "How is my number one intake valve getting bent when the valve timing is correct"? The engine now has 270596 miles on it. Any suggestions? Thanks. Bill
