1 - 12 of 12 Posts
I just got a Skunk2 Intake manifold that I plan on installing myself and I was wondering if anyone had any links or anything that shows a step by step instruction on putting this on. And does anybody have and hints or anything that I have to look out for. All help will be appreciated thanks.
aw man, i went thru the pain of installing a Venom intake manifold on an LS motor before (not mine).
Hint: DRAIN YOUR RADIATOR BEFORE INSTALL!! otherwise you'll have coolant all over the engine bay from disconnecting the different hoses...
Hint2: GET A FRIEND TO HELP!!! trust me on this, you'll need one to help you with removal and install!
Hint3: GET A SHOP MANUAL! do not get chiltons, helms is best but haynes will suffice.
Hint4: MAKE SURE YOU HAVE PLACE TO CoNNECT all vacuum lines, sensors, and the throttle cable before you install. Other wise you'll be needing parts for IAC and such.
Hint5: IMPACT DRIVER is needed for some sensor screws that will NOT move for a regular screwdriver.
i don't know what the S2 instructions tell you but be sure to purge your fuel line thru unbolting the banjo bolt on the stock filter in the engine bay...hope that helps.
I would even go so far as to say, make extra, especially sure you label all of your vacuum lines and wires. Swap the wires and lines over one at a time, and try to do it all in the same session.
Wow this seems like I am going to have quite a bit of work ahead of me huh? I might just have someone do it but I would really love to do it myself so I could learn a few things.
no no no...don't let it scare you. Yea sure its more of an undertaking than installing an intake tube. but if you follow the s2's instructions and a shop manuals...and follow the advice on here, you'll be fine. its a good feeling of completing a project of this difficulty. besides, it'll bring you closer to your engine.
I just got done doign a head gasket replacement on my 94 LS and I have NEVER done anything like this on a import....my suggestion on getting the 2 middle bottom nuts on the manifold is jacking up your car and getting to them from a bottom with a 13mm??? wrench, ALOT easier then going from the top, the other two bottom nuts are easy to get to with a wrench! I am getting a skunk2 manifold too! Let me know how much of a difference it did for you k!!
The skunk2 manifold I got has a direct port 70 shot in it so I am sure that I will love it. Where can I get a hold of one of these shop manuals at?
haynes can be found at pep boys or auto zone.
get ready to cuss and get mad. This project is one pain in the ass lol. So many hard to reach/non visible areas when working on that thing. Make sure you have everything right because if you have one thing in the wrong place then it wont run right.
yea i know, but its helpful when you don't have the patience to sit and wait for the helms to arrive.
one mistake i found in haynes, they dont have the correct plug-wire setup. they have #1 in the top-left corner going clockwise. however #1 is lower-left corner going right to #2, then #3 is top-left, #4 going right of #3. just wanna clear that up...
1 - 12 of 12 Posts
