well i replaced mine with a grant steering wheel which was only like $40 cause i dont have a lot of money for a better one.
there is a couple plastic pieces the pop off that reveals screws and what not, but just look around and you will see what screws need to be taken out, then you unplug the yellow airbag cable(which runs to a plastic piece that you will see once you get the wheel off and then runs under the dash to a connector, but you just take all that out of course)but the airbag will come right out revealing a big hexnut that tightens the wheel down...you get the nut off an there ya go..the rest depends on the steering wheel you plan on putting on and the installation kit which will have instructions...
integra24 what do you mean where does the airbag go? unless you buy a aftermarket steering wheel with an airbag(which means it comes with one) then the old one goes in the trash(which you shold keep just in case) cause aftermarket wheels dont have airbags let alone a place for them unless like i said above
