I just installed my pro-kit/koni yellow combo.
Before the install, I had 4 finger gaps in the front and 3 finger gaps in the back.
After the install, I have 3 finger gaps in the front and 2 in the back.
That is only a drop of .6 for the front and .7 for the back. ( I measure my finger )
Does this sound right?
I am running on 205/50/15s.
Did you measure your original gap with the 205/50 or with the 195/55 tires? They will settle in a little bit, give it a week. Possibly the spring perch on the Koni Yellows wasn't set to the stock position. Koni Yellows give you ability to alter ride height by +/- 0.5" so you still have that to play with if it's not as low as you like.
I measured the original gap with 205/50. The perch on the Koni is set to stock position. (front: top perch, rear: middle perch). I wanted to use the lower perch for the front. But the shop was telling me that the spring is going to be to loose if I use the lower perch and that it will be bad for the suspension.
