No. Do not follow this advice.Exploit on Jan/28/06 said:Try this Sea Foam Cleaning and use some Lucas Oil treatment
Well I used them and it stoped the ticking in my car.JustinKlemgold on Jan/28/06 said:Quote: Exploit on Jan/28/06Try this Sea Foam Cleaning and use some Lucas Oil treatment
Honda injectors are clicky by nature. Valves can be adjusted. Seafoam and Lucas oil treatment are just blind suggestions that will cause more harm than good.
drftnda on Jan/31/06 said:i have a another ? my car keeps reving funny it goes up 2000 rpm and then it drops to 1000 and repeats on doing it.What can it be ?can it be related?
I don't think its related but mine did that and I just had it fixed, its most likely your Idle air control sensor, I replace the throttle body with just another used LS one and then adjusted the air bleeder screw on the top of the throttle body and it stopped. Try just adjusting that screw first, you only need a flathead screwdriver.drftnda on Jan/31/06 said:i have a another ? my car keeps reving funny it goes up 2000 rpm and then it drops to 1000 and repeats on doing it.What can it be ?can it be related?
