Hay Fellas i have a couple problems with my car
Background, 96 GS-R 138k stock ignition, IM, fuel and related components
it does have NGK plug wires along with Iridium Spark plugs. last summer i changed from a Blox IM back to stock IM.
the codes are:
P0304- cylinder 4
P0172- fuel to rich
P0302- cylinder 2
P1300- Random
P0441- Evap emission control
incorrect purge flow
Any body know what any ideas might be, i have heard that the purge valve goes bad, but why would the system run rich? injectors sticking?
any help would be great thanks guys
Yes reset the ecu already i used a code reader, but the engine light came back on for the same reasons
I'd take a good hard look at the EVAP issue. I havn't ran into much of it involving our B series motors but the EVAP system can wreak havoc in mysterious ways when not functioning properly. Get to the bottom of that issue first.
Hey,
how is everything coming along with your misfires? I actually got the same exact codes going on. Changed my spark plugs, wires, distributor cap and rotor and still getting a misfire. Im going to check the continuity on my fuel injectors but wanted to see if you solved the issue with yours.
