Ok...I already try looking for my idle problem in team Integra..but didn't solve my problem.... My car would idle normally when cold start. When it reaches normal temp. if i press the gas pedal, the idle will bounce between 1,000- 2,000 rpm back and forth. I clean the idle control valve with carb cleaner and it didn't work. I swap to a different one, but still same problem. When the engine reaches normal temp. i cover the top hole on the thorrtle body and the engine will sound normal..or i unplug the idle control valve and it will sound normal too.(idles under 1,000).Any help will be helpful..thanks
Discussion Starter · #2 ·
Could it be a vacumn leak or is it sensor??? I three codes 7,14,43 by jump wiring on the harness under dash. 7 is the TP, 14 is the idle control, and 43 is fuel probelm.
