I read the post on here about adjusting idle. I warmed the car all the way up by driving for a bit, parked it, while running removed the IAC connector. RPM's dropped roughly by a hundred as down to 450 from 550 where its been idling. I proceeded to adjust the idle screw and as i was turning it counter clockwise the car all of a sudden dropped to 250 rpm and didnt adjust at all. While i was adjusting it i turned the lights on which pulled the idle down more, would that be why or is something else the cause like the throttle body?
To the best of my knowledge, the idle screw really isnt supposed to be adjusted. Why are you adjusting it, because it was idling at 550?
I don't think there would be a idle adjust screw if it wasnt meant to be adjusted. I managed to get it to idle at 700-800 after a second attempt this afternoon.
There is one there, but from everything ive read its to be adjusted basically as a last resort. But since it fixed your issue, can't be mad at the results.
It was a last resort in my case but may have been half the problem to begin with. I cleaned the IAC valve and it stopped hunting plus i replaced my fuel injectors and the sputtering at idle stopped. After that it wouldnt idle above 550 except when warming up. When i finally read up on properly adjusting idle i went to attempt it and discovered the previous owner had damn near stripped out the head by using too small a screwdriver and by not cleaning all of the plastic out of the groove. im thinking he just went straight for the screw instead of messing with the IAC valve.
