ok , so i reset the ecu , and drove it around the block , when i first start it it just sits at like 3000 rpms , then i guess when it warms up more it startinggoing from 3000 or 2500 down to 1 then up then down and up and down again and again
it drives fine . . but i turned it off and tryed to start it again and it would just click once and die ( no power) so i had to jump start it , then it worked fine to atleast bring it back 1 block to the shop
my alarm isnt as loud as before the accident idk gimme info , i am searching on more then one forum so i just want lots of suggestions of things to try.
what about the IACV or THE PCV valve or fast idle thermo valve ??
i am getting a small amount of smoke in the engine bay , all white smoke and the idle surges still
i let it still for a while runing to warm up , then the idle surges , the i drove it and it still surges in neutral and when the clutch pressed down( neutral)
please help ,im out of money and dont wann bring it to a shop ( that would be using alot of money)
i have also heard that about my headgasket because of the white smoke . . .but that was just a thought i had
