Well, I have a b18b, with I/H/E. I would like to tune it, but the issue is that there are no places to tune within 900km. The local pressure is 93.5 kPa and is well below the normal sea-level 101.325 kPa. So the car could be running either richer or leaner, depending on which map it grabs. Either way, the mods are making the car run rich due to the higher flow rates. So, I have been reading up for a while on tuning and I still have a few questions. I would like to street tune it, and my 6 month old laptop can help me out.
The climate changes from +30 to -30, and there’s a week of solid -40. I know that the air density will proportionally change with temperature. So when it’s hot, we have a lower density air, which will change the fuel map for that temp. Then when it’s cold, the air becomes denser and changes the specific fuel map. So let’s say its 1 bar pressure and it get hot out, so this reduces the atmospheric pressure (0.9 bar) and the computer grabs the 0.9 bar fuel map. For cold, it does the opposite. How do standalones account for this? Or, do u have to tune it for winter and summer?
I was thinking of going for a piggyback. This is because it has the reduced cost, and its features. I know that as you lean out a specific RPM, the ignition will also advance. The change in ignition and fuel, will combine together to achieve the desired A/F at the specific RPM. The nice part is that as you reduce the fuel duty, the ignition advances and you achieve the leaner situation with a smaller reduction in fuel duty when you compare it to only reducing the fuel duty only. This is because as you advance the timing, it gives the fuel more time to burn, and hopefully no detonation.Is this wrong?If detonation occurs; use a higher octane or richen that rpm to prevent?
Another thing about piggybacks is that they change with the stock fuel map. This allows for the stock computer to adjust for the change in temperature. Then the piggyback changes the stock fuel map proportionally, by moving the fuel map into a lower atmospheric pressure fuel map.
I’m not sure what brand of wideband O2 sensor I should use. I want it to be compatible with my laptop for data-logging. Any suggestions? Keep in mind, I have a limited budget.
I don’t think I need a fuel pressure regulator, because I’m just interested in leaning out the car. The only time you need a FPR is for making the car run richer, right?
I don’t think I need Cam gears either, since I’m not trying to change the overlap, and I want to keep the stock overlap. Correct?
Oh, and I’m not intending to go into FI or N/A buildup. It’s my daily driver, and I don’t want to sink too much cash into the car. Just improve the efficiency and available power, while having fun doing it.
I know it's a little long... Any technical advice would be good. namebrand opinions can be kept to a mininium please. You dont have to water down the info either... im in my 4th yr engineering, so more technical is better. even textbook referances are good too.
