I'm sure you've done your research, but you can't just throw on a turbo and think that things will run smooth. You may need to change some internals as well as the standard bolt on type mods. To properly turbo your car can cost two or three grand. You can cut a bunch of corners and get the most expensive 50 horsepower in the world by going low budget, but I'd suggest doing it right. Or just screw it and buy a car that is already turbo. At this point you'll spend 50 or 60 percent over what your car is worth in doing a good turbo job. Start saving lots of nickles and dimes.
