How do you disconnect the low beam bulb from the plug? Do I just pull it out? And how do i take the bulb out of the housing? Do i also just pull it out? I'm worried that I might break something so Im asking you guys first.
pop the hood, there is a rubber housing on both side of the teg where the light is suppose to be, you'll see it...you just have to turn the thing counter-clockwise or clockwise(not sure), then pull it out, your'll see a cliplike thingie holding bulb, the rest will be easy and common sense...hope it helps
z317's got it. you turn counter-clockwise to get the bulb out of the car's lense, then you just push on the clip that's holding the bulb in and pull it out.
warning though, the bulb is sometimes very hard to get out. When I was taking mine out, one slid out like butter and the other one I had to hank and pull and put all my muscle into it for a good 10 minutes before it budged.
and remember! don't touch the bulb you're putting in with your fingers!
