Don't do it this way, that's the stupidest thing i've ever heard. It may work for a while, but eventually it'll leak.integrals21 on Sep/05/07 said:it'll be cheaper if you have a driller or know someone who can borrow you a driller...use jb weld or qiucksilver to do the welding get it at wal-mart for about 5 bucks..otherwise go buy a driller use it to drill the hole, jb weld it or use qiucksilver and return the drill the next day....
integrals21 on Sep/07/07 said:it'll be cheaper if you have a driller or know someone who can borrow you a driller...use jb weld or qiucksilver to do the welding get it at wal-mart for about 5 bucks..otherwise go buy a driller use it to drill the hole, jb weld it or use qiucksilver and return the drill the next day....
actually thats just the method us cheap homemade turbo guys do it...didn't mean to startle you buddy...several cars i know done this method and have no leak problems...
shouldn't cost more than $30....
if you are going to jb weld, just make sure the area around it is hella clean and sanded up good. i fixed my radiator with jb weld... first tiem i did it i dint clean it up good and it leaked, so i cleaned it all up, sanded it and did it again. no leaks for more than a year and a half now.integrals21 on Sep/07/07 said:it'll be cheaper if you have a driller or know someone who can borrow you a driller...use jb weld or qiucksilver to do the welding get it at wal-mart for about 5 bucks..otherwise go buy a driller use it to drill the hole, jb weld it or use qiucksilver and return the drill the next day....
