1 - 17 of 17 Posts
I just ordered 17" rims with 40 series tires and now i was wondering how much of a drop would i need to get rid of the gap and make it look sweet. If you can, can you please post ur car w/ the type of springs and amount of drop?? Thanks!!
neuspeed sports look really good in my opinion. It's the perfect height from waht i've seen. Putting mine on saturday so i can post some pics if nobody else does. It's 1.75 in front, 1.5 in back
here's my car. i have ground control adj. coilovers with tokico's. the rice isn't that bad at all. anytime you lower a vehicle you have to expect it to be a little stiffer, but if you get the right setup it won't be bad. with the GC's all the way up, you still have about a 1" lower than stock drop. with the GC's if you go lower than 2" you should get the camber kit as well. expect to pay around $700 or so for everything.
to actually use the adjustable advantage of coilovers and have optimum performance you would need to corner weight the car everytime you change the hieght and have an alignment.
That is why springs are more practical. Plus I don't think people change their height that often, unless you are a true autoX person.
1 - 17 of 17 Posts
