I see some oil on my block, in the front, where the head meets the block. Im pretty sure its not the headgasket since overheating is a problem with a bad headgasket and im not overheating at all. Im thinking it could be my cam seals, but im not sure. Any help would be appreciated.
its most likely your cam seal cap..a common problems on integra b series motors. just look up under the cam seal cap and see if there is a lil bead of oil under there and if there is thats ur answer
Yea right by the vtec solinoid. I was leaking from the vtec gaskets and cam seal. guys at acura says its a commin problem, I picked up a STR cam seal the the two new vtec solinoid gaskets, and no more oil. Been almost a month and nothin. Install pretty easy, just need to torque head bolts good
cam seal cap being on passenger side of the motor correct? If i were to need new cam seals, should i go aftermarket or stay OEM? could they be done by me, or should i take it to my mechanic to get it done?
edit, while typing this i got the answer. thanks guys.
