Er, we were installing angel eyes on my friends 94 4dr LS and it only had one horn.... I have a 95 4dr LS, so I dunno... I've also heard from a friend that you can tweak a horn to be lower or higher???booley on Feb/22/04 said:my g2 has 2 horns, are the g3's the same? anyways, one is "low tone", the other is "high tone". try unplugging either one or the other, to see which sound you like better......
they were on opposite corners behind the bumper cover, i'm using past tense because i did remove one, and now the other sounds waayy differentbooley on Feb/22/04 said:my g2 has 2 horns, are the g3's the same? anyways, one is "low tone", the other is "high tone". try unplugging either one or the other, to see which sound you like better......
