1 - 19 of 19 Posts
hello everyone, its been a wile sence i have posted becuase my car was runnign really well. now i have a problem, on the hondata s300 there is a boost cut safety feature. my car is set to run 16 psi with a 12 pound spring and 4 psi with a hondata electronic boost controller. if the car creeps to 19 psi the boost cut safety will come on and cut the engine out. everyone was all good and the boost cut would only come on when it was super cold out. like minus 5. now it comes on as soon as i hit boost in 3rd gear even when its plus 30 out. i dont no if its the boost controller actaully letting in more bost or the hondata 4 bar map sensor screwing up and seeing more boost. i dont know where to go from here. any advice?
You have to adjust your boost controller when the weather changes.
I turn down the duty on mine when it gets colder outside.
Discussion Starter #4
wait. my car was tuned when it was cold out. so now that its hotter out wouldnt it run less boost?.. if i got it tuned when it was hot then it got cold then i would understand why it was running more boost becuase the air is more dence. but this is the oposite... im confused lol
Do you know how to work your boost controller? It's an easy fix and I'm willing to bet it's what's causing your problem.
Even if it's not causing your problem, it's easy as pie to try so you can eliminate it if it doesn't fix things.
Discussion Starter #7
yea i know how to use the boost controller. well pretty well i get the idea. ill have to take it slow.. what do you recommend just turning the boost down on there a bit? i dont understand why it would be running more now though? well shoot me an idea there because it sucks not being able to boost lol.
If you are hitting your boost cut, your wastegate is opening too late...adjusting your boost controller allows it to opening sooner so you don't boost to your cut.
You fix this by turning the duty cycle UP on a boost controller. I'm not familiar with your boost controller but if you have it, you should know how to make this adjustment.
get the laptop out and datalog some runs, make some changes, and see where you are at. also, what is your target boost set for in the software? maybe you want to lower it, but keep the same duty cycle. the solenoid will stay closed until it hits that target. then it will start cycling at whatever duty cycle you have entered for that gear.
Discussion Starter #10
ok im going to try to figure this out tonight. for some reason the car will boost fine in 1st and 2nd without any cut. but as soon as i hit 3rd and 4th gear if i give it any more then 50% ( roughly) throttle it will cut out, its wierd why it only does it in 3rd and on and not second. im just wondering why it changed all of a sudden and it seemed to be getting worse. i could boost before at like 0 degreese. then the cut started coming on slowly. at plus 5 then 10 then 15 now like 30 degreese cels it comes on. anyone know why it would just change or get worse..? i would understand it more if i got it tuned when it was hot out and then when it got cold it would cut becuase of the air being more dence but this is backwards lol.
Discussion Starter #12
i dont understand why it would just happen now.. the car was pro tuned 4 months ago and its just been screwing up and getting worse. im wondering if maybe the solenoid is screwing up?. ill try all these things tonight and let you know whats going on.
i had the same problem with my turbo setup.
s300 and hondata boost solenoid.
it would suck driving at full throttle boost cut, i would have to partial throttle when driving.
i had my car retuned for 2 programs, 1 street tune and 1 track tune. The tuner said it happens when things start to break in on your turbo setup. its part of owning a turbo. just retune it.
He adjusted the duty cycle as mentioned above.
now no problems. holds constant at 15 lbs my boost cut is setup on 19 also.
Discussion Starter #14
i figured my problem out kinda lol. i checked the physical setup closely and there was a small slit in my vacume line going to the boost controller. i guess the slit got bigger over time and it got worse. no clue how that happend maybe a rock or something. i went for a cruise tonight and it boosts a lot better but still under full throttle it cuts. i can use about 80% throttle now instead of the 30% i could use before lol. i can actaully get into vtec now lol. i have to investigate further..
Discussion Starter #17
this is an old thread i made but i figure i would update. problem was a faulty hondata boost sonlenoid. i mounted it to my crash front crash bar with screws. i found out later that the solenoid can not be mounted solid. it has to be mounted with some type of rubber buffer so it does not vibrae against a solid surface. it has to be able to kind of free float. i have a new one now and am going to instal it.
1 - 19 of 19 Posts
About this Discussion
9 Participants
Built_not_bought
Team Integra Forums
Full Forum Listing
