what would you be satisfied with ? (i.e. make you happy realistically)
As I said to you in our discussion tuning the fuel is a huge part of making the car driveable and perform. A stock ECU on a 310 injector would run horribly if left untuned. You'd be washing out your cylinders and lowering your ring seal.
I don't know why you went to a 310 but since you already have it, you must lean it down sufficiently. A stock 240 injector flows enough for 175 whp with adequate FP settings.
Having too much fuel will protect you from detonation but the burn efficiency is negatively affected even with 10.5:1. So reading your WOT af ratios from 5000-6500 rpm in an LS revving to 7000 rpm is important.
The second limitation to top end power in an LS is it's head. The head is what sets your peak potential. If you can't flow enough through the ports, it doesn't matter how much cam you add.
you need to have enough air (also called mass flow, flow volume, flow capacity) to make a certain peak hp number. If the head can't get you that much air, you won't meet your expected peak goal no matter what you spend.
The IM upgrade should help.
The 12:1 CR: why are you going so high?
here's some useful info from 2 sites you can apply:
Cams for B18B1 / B18A1
bore 3.1889 in., stroke 3.504 in., rod 5.394 in. ,0 boost, 600 ft altitude.
Dynamic CR calculator
cylinder pressure (psi)% change from stock
stock 181-
Crowers &
10.5:1 20312%
Crowers &
12:124133% !!!
That is seriously undercamming the motor and would blunt your top end (> 26% increase in cylinder pressure). You'll get a gain from the burn efficiency increase of 1.5:1 CR (assuming proper fuel tuning and adequate mass flow) but the undercamming will lower it's potential (expected power from CR increase is 1% per 0.1 increase until you undercam = 175 peak whp).
11.0 to 11.4 static CR would give you a 20 to 25% gain in cylinder pressure (recaptured) and all you need.
using skunk2 high CR valves and a thinner headgasket would get you there without having to swap the pistons (as long as your walls aren't washed out and ring seal affected by those 310 injectors).
If you fall short, you'll know where 2 potential sources are.
getting a 4-1 will help your top end.
