1 - 11 of 11 Posts
I think one of the Transformers on my HID kit went out on me. Is there any way to repair it or do I have to buy an entirely new Transformer? I swapped the transformer to the other light that works and that side didn't ignite either. So I'm guessing it is the transformer.
Any ideas on what I should do to fix it or am I farked?
Thanks
90_DA_Teg on Feb/27/04 said:
He already said that Jason in his first post.
he didnt say he swapped out everything ,there is a ballast , blub, and relay in each kit(x2) , so 3 peices or 6 all together . . . if you only swap out some of the peices you arent doing a real and proper way of isolating the problem you can half way do it . . .
I swapped out the ballast from the side that didn't work to the side that did work. The ballast never switched on. I checked all the wiring/bulb and connectors on the broken side first and they were all in working order.
Anyone know where I can get a Philips Ballast for cheap? :)
1 - 11 of 11 Posts
