1 - 17 of 17 Posts
· Registered
Hey has anyone taken off their sunroof yet. I tried to but its soo hard!! I put in the wrench sticks or whatever you call them to take out the screws and it want to strip the bolt when i take it off. Anyone got any ideas??
· Registered
I dont know how to take one out but was wondering if anyone knows how to fix one ...Mine drags on the way out but slides back in fine should I just lube it up?
· Registered
halfac, yep just lube it up, there is another post where they recomend what to use but can't find it. maybe someone will let you know.
chop, i have taken it off, what part were you having problems with, i am taking it off soon again cause i am getting white vinyl installed on it.
· Registered
I am having troubles with taking out the screws. I dunno if its been soo long and rusted so i am having probs or what.. but I tried with all my power and it sorta just stripped it. Wont budge at all!
· Registered
i got that same chattering too when i open it. it also does it when you close it fully from the tilt position. i looked at it close the other day and wiggled it and you can see where the runners almost look worn out, i don't think there's anything i can do to fix mine besides get some new pieces.
· Registered
Try an impact skrewdriver on the skrews. It's bassicly a skrewdriver that when you hit the handle with a hammer it turns the bit, pretty much any hardware store will have em.
(But dont go pounding on it too hard, dont want to damage you're roof lol)
· Registered
The clearance is so tight and most allen keys are so tiny, that you can't get a good angle on it.
I was able to get mine out by removing the engine assembly, tiling the assemble on its side, and manually opening the unit just a few inches. If you are striping the head, make sure you are using the correct size, which is 5.5mm, if I'm not mistaken.
It's a real PIA. If you've already got another unit, just pop the glass with a hammer and make yourself some clearance.
1 - 17 of 17 Posts
