can u guys help me out where to mount my ground wire for my amp on gen 3 tegs. all suggestions will be helpful. thanks. by the way im hookin up 12" subs Infinity Kappa.
ack! why drill a hole in your car that you don't have to?CustomGSR on Feb/15/04 said:If you got a drill do it right. IMHO. Stay away from the gas tank. Get a bolt that will fit through the ground wire connection, a lock washer, a nut, sand paper, and spray paint or silicon.
Find a place in the spare tire well.
1. Drill a hole
2. sand away the paint
3. Put the ground wire on the bolt and insert into the car.
4. Then ratchet away on the bolt. Make sure the lock washer's on the bottom. (<<<Yeah, I know you know that.)![]()
5. Then paint or silicon over the head to combat corrosion.
If you think you'll be disconnecting everything a lot. I compete, so I'm always changing my system. Get conducive hardware and an extra washer and nut. Put the head of the bolt on the bottom of the car so the threads are on the inside. Install one washer and nut. Put on the ground wire, then install the last lock washer and nut. That way you can always Add and remove grounding wires by just unbolting the one nut.
