1 - 11 of 11 Posts
I would have to say it's 6 bolts.
2 bolts on each side to remove the brake line holder.
And 1 bolt to remove the arm from the subframe. That's about it. Spray WD-40 the night before you work on it. I found that it's easier that way and helps soak into it so you can break it open with ease.
Damn I sound like I don't know s--t about this. Gonna get a friend to help me put it on. Thanks for the info. But does anyone know sites that will show pics along with instructions of how to install rear lower tie bar???
one piece of advice....use another jack! This 2nd jack will be used to hold the control arm in place to get the bolt thru. If you don't, you'll see why i recommend this.
hahaha yeah take LT6916's advice...
and keep the rear tires on...it helps push inthe LCA's.
Remember too.....you can only take out the bolts...the nuts are welded. Take out the bolts (rear side of the car).
dah, my Comptech one required me to drill eight holes (took two of us two hours to get this beeeyoch installed)
looks like the sway/tie bar "kit" is a heck of a lot easier to do since that tie bar uses existing bolts
I have an OBX rear lower bar sitting in my garage waiting for installation. is it really worth putting it on or is it just eye candy??? i have both uppers installed... will the extra support be noticeable?
yeah the comptech one was a pain, but I think the design gives it more support than the others.
Adam
1 - 11 of 11 Posts
