1 - 2 of 2 Posts
I just bought another 94 acura integra sedan, the other day I tried to race someone and when I stomped into the gas hard it basically died, you can drive the car hard and itll do just fine. But when you really really want to give it all it has the engine cuts out and losses all power for a few seconds then will come back after I let off. Could someone please help me, it's a very weird problem. The teg has a b20b with an aftermarket Intake. What could cause the power loss? I NEED HELP!!!
Look into full pressure. Injectors, filter, or even pump sock could be clogged. Might need a fuel pump. Injectors/injector could be bad or locking up. Make sure all your grounds on the car are good and grounded. Many of possibilities.
1 - 2 of 2 Posts
