My problem: long starts in to crank engine
This started occuring the second day after i installed my new cap/rotor/ngk copper plugs/ and wires. Im pretty sure i did the install right with 20lbs of torque on each plug.
I put the wires back on the distributor in correct order starting from bottom left to bottom right to top left to top right order.
After i finished my install two days ago, the engine turned on instantly and everything was smooth and running fine.
So now my engine takes a while to crank. I can't figure out the problem; i checked the plugs with correct torque specs. ANY help would be much appreciated thanks all.
when you were replacing teh cap and rotor did you possibly knock the distrubuter out of position?
Perhaps you should check your ignition timing with a timing light, make sure its still in spec.
