1 - 2 of 2 Posts
I want to say sorry to begin with im a young mechanic and I just got into the honda scene so im a little unfamiliar.. first I want to do a ls vtec build I have a 98 Integra with a b18b1 with 165 I wanted to ask if I bring in just the block how much would a shop.charge to rebuild? Then second I just started reseaching ls vtec but im still a little confused I know I want to go with a b16 head but what ecu would be good for this swap and is there rewiring required for this swap?
p28 would be a good option. I have one for sale if you want it. And the only wiring I noticed when I did my lsvtec swap is that the LS has this purge valve thing on the intake manifold that the b16 did not. To keep me from blowing any codes, I just unbolted the solenoid and plugged wiring in to it and tucked it behind the intake manifold. Also, you will need an obdII to obd I conversion harness for your ecu which i also have if you want to buy it. As well as the vtec wiring.
1 - 2 of 2 Posts
