So back when I removed the engine, I was removing the heater core hose and dented the driver side ( idk if that's intake or out flow side) and now since I'm temporarily using distilled water... i hear a hissing noise from what seems like the heater core. I noticed a lot of that water dripping from under the car which I'm assuming is the water leaking from radiator hoses.
Is there a tool to repair that dent, can I wrap something to fix the gap or can I use some aluminum welding stick (heat up the tube and add the stuff)?
Is it the factory heater core? the factory heater core in my car was pretty easily bendable without heat. i ended up replacing mine though since mine had 225K on it at that point.
Those nipples are very, very thin walled. If you can't find a heater core, you can bypass it completely and live with no heat.
