1 - 20 of 25 Posts
I got some heat wraps. But i hear bad things and good things about them. I have a integra with DC sports headers 4 to 1 i need to get some good opinions should i put them on. I hear that it will eat the headers up from to much heat and then i hear that only happens if they are cheap headers.
I really dont know???
Actually, this is from tuan's intake tech article on hondavision
He uses an Iceman CAI made for a SOHC VTEC (tapered 3.5 in. OD to 2.75 ) in that 11 sec Integra LS VTEC with an Endyn ported head, Jun 3 cams, high compression, and SMSP header. He wraps the intake with 2 layers: header wrap and then reflective tape (like Kooltape) . He claims that this manoever gained 1-2 whp throughout the rpm range. Funny thing is when I talked to Knight Engineering, the makers of the Iceman, they said that their intake (made of plastic) does not need wrapping. Jeff isn't the only one doing this.
doesn't using heat wraps on headers void the warranty depending on which brand of wrap and or header? i though i read it somewhere, in a magazine... correct me if i'm wrong...
ultraspeedefro on Aug/14/02 said:
ya theye are creamic coated but the actual header is stainless steal.
It's not stainless steel, it's mild steel, and will crack if you wrap it. The only headers that are worth wrapping are cast iron manifolds like the stock JDM ITR. The others that are ceramic coated or stainless steel won't see any benefits.
ive had header wrap on my car for about 4 months and its been fine. i also have a cheap hp racing 4-2-1 header that i payed $30 for so i could care less if it snapped in half.
why does that not sound so re-assuring to people with headers they paid more for? 4 months...
what is someone supposed to do with this info that you gave?
not exactly the most helpful or useful info....
Those worried about the heat from the header soaking the intake piping/filter, could buy $10 worth of alluminum sheetmetal and use some brain power to fab a heatshield.
Cheaper than headerwrap, not only in initial cost.. but also in the cost of having to replace your expensive aftermarket header.
1 - 20 of 25 Posts
